Hi all....
After searching and reading the MANY posts about different airbrushes in this forum, as well as doing a lot of reading on the web, I think I have my selection of which airbrush to buy (my first one!).
I would like to get the opinions of some of you AB vets out there first.....
I mainly will be making aircraft. But I would also probably venture into all areas of WWII modeling (even dioramas) including Naval, armor, and figures.
My first project (after I do several practice projects to get techinques down) will be a 1/72 scale German U-boat (Type VII-B to be exact). It will be about 3-1/2 to 4 ft long.
So what Im looking for is something that I can spray that big of model with, and also do fine detail work on.
Question:
1) Can you do such a large project (like painting flat grey on the WHOLE U boat) AND also do detail work with the same AB?? Or do you generally have one AB for General large work and one for fine detail? Or is that taken care of by the different Nozzle sizes and needle settings? (Ok so thats 3 questions)
2) The brushes that I seem to gravitating to are the Badger 155, Badger 100LG, Paasche H, and the Passche VLSTPRO. Which of these (or any others) would you all reccomend? I lean towards the Badgers as they seem to be the easiest to clean and get parts for.
I will be getting a compressor to run the AB off of. Im not afraid to learn the double action brushes as it seems that once you master the double action, they seem to be the most verstile. Am I wrong in my thinkning here?
I just want to get a good quality airbrush that a year from now after my skills improve, I wont be wanting to run out and buy a better AB. I would rather invest the money now than waste it later
Thanks for any and all suggestions! I look forward to sharing/learning from all of you in the future!
