- Member since
Posted by ABARNE
on Tuesday, July 5, 2005 2:21 PM
Actually, the Cyclone I is a diaphram type compressor, and the problem that you have described is not inherent in the design. I have owned one myself for several years, and the pressure is quite steady. The pressure will naturally drop a couple of PSI when the AB is opened, but with the air flowing through the AB, the pressure will be fairly constant.
Andy
