Help w/ removing latex masking agent.....
    February 2005
Posted by MA Cooke on Sunday, July 10, 2005 9:31 AM
I used latex mask on the wheel wells of a couple of models, and I'm having a VERY difficult time removing it. It doesn't want to come off, and I'm tearing and scratching the ever-living daylights out of the wheel wells.
Does anyone know if it can be "dissolved", or at least softened, with Windex, isopropyl alcohol, etc?
Thanks everyone.
Mitch
On Bench: AM P-51B, Tamiya 1/48 F4U-1A On Deck: Hasegawa F-14's (too many); Tamiya P-47D; Academy P-47N;
    January 2004
Posted by MusicCity on Sunday, July 10, 2005 10:38 AM
Welcome to the world of people who have found out the hard way that that stuff is more trouble than it's worth.
I don't know of a way to dissolve it but you can try using some tape to pick it up (I've been so desperate before that I've used the stickiest duct tape I could find). Sometimes that works, sometimes not. A toothpick can also be used to lift an edge so you can grab it with tweezers.
    February 2005
Posted by MA Cooke on Sunday, July 10, 2005 11:15 AM
UPDATE:
I poured isopropyl alcohol (70%) into the wheel wells and let that soak for a while (hour or more). That did the trick. It's still difficult to get out, but I'm using a toothpick, Q-tips, and Micro-Brushes and that is doing the trick. It's tedious, but I'm not marring the wheel wells at all.
The alcohol softens up the latex, and breaks it up to the point that it comes off the plastic quite easily. Far, far better than peeling off the mask "dry".
That liquid masking agent will NOT, I repeat WILL NOT, be used for wheel wells any more! It will stay on canopies, and that's about it.
