Hi,
I'm thinking of building one (or buying a respirator...).
I'm planning to use an opaque plastic box with lamps and some ventillation, but I have a few questions.
I'm not really familiar with electronics; I need a fan that's not going to bust into flames when the organic solvents reach it. Also, how do you attach it to the electric grid? (I mean the fans I saw do not work with 110V. Should I get a computer power source and some cooling fans for CPUs?
Where do you went the fumes? I rent an apartman, and I don't think my landlord would be extatic if I cut a circle in the window for the tube... Do you think placing the box to the open window would be enough?
Do I need a filter before the fan? If I do, then what kind?
And a bonus question (I don't want to open a new topic): how on Earth do you make Alclad metal-like? I used testors gloss black as a primer, and on one part Alclad is really superb, while on the other it's flat... Why's the difference?
