Accessories for CH Quiet Air?
Posted by Anonymous on Tuesday, July 1, 2003 1:50 PM
I bought the Campbell-Hausfeld Quiet Air compressor, and the manual says you should install the air filter MP 3108 to catch moisture. Unfortunately, I can't find anyplace that sells that filter -- the closest I could come was the MP 5138.
So, you guys out there with the Quiet Air, what kind of pieces did you need to buy to add the moisture trap? Any actual part numbers would be greatly appreciated.
Randall
Posted by Anonymous on Tuesday, July 1, 2003 10:38 PM
Any 1/4PT (that should be the thread off your regulator) moisture trap should work. The only reason they would recomend a CH is because they get more of your money that way! Should be available at any decent hardware store.
Posted by MikeV on Tuesday, July 1, 2003 11:30 PM
I hope your C-H Quiet Compressor lasts, from all of the reports I have heard they don't live very long if used very often. Sad [:(]
