How many coats of main color?
    July 2005
Posted by Barruel on Thursday, July 21, 2005 9:04 AM
Greeting from Portugal
I have returned to the modeling hobby after a 25 year break and found out this brave new world of airbrushing, drybrushing, photo-etched brass, acrylics, etc. etc.
After buying a second airbrush (a double action Harder & Steenbeck Evolution - the best way to paint german panzers is using a german airbrush!!!) to make company to my still working almost 30 year old Badger 200, a silent compressor a lot of acrylic cans of paint, I still have a basic question concerning airbrushing:
I am using acrylics (Vallejo and Tamiya) after priming (Tamiya spray can),
and I would like to know how may coats should I give for the basic main color.
I am using only one coat, and a second hand just to cover some spots not covered in the first one, but I think it is not enough because sometimes during the washings (artist oils with enamel thinner) I remove the basic acrylic colors!
It should not happen, since they are different mediums (or so I have read somewhere), but it actually happens.
Is the basic color coat too thin, or should I give a clear flar coat between the main color layer and the additional washing and weathering coats?
Could someone give me some help? Thanks.
Posted by Anonymous on Thursday, July 21, 2005 10:02 AM
Well before you do a wash you need to spray your model with future, this will stop the base coat from comming off/lifting. After the wash I spray another coat of future and if there is nothing else to do I spray it with Testors dullcote.
Hope this helps.
    July 2005
Posted by Barruel on Thursday, July 21, 2005 10:17 AM
Thanks for the tip, unfortunately the famous Future is not available in Portugal
(at least under that brand name). Can I replace it with something else?
A clear (flat or glossy) coat, perhaps?
Posted by Anonymous on Thursday, July 21, 2005 11:39 AM
Barruel-a laquer clear coat will do. But also remember that finger oils secreted by your skin can remove paint. So don't grip tightly-or better yet use cotton gauze gloves. If you can't find them put an athelic sock on your hand-you can trim it down if you want. BTW-less paint is better-you won't lose detail.
    July 2004
Posted by tho9900 on Thursday, July 21, 2005 8:25 PM
Barruel -
look for Pronto Cera Acrílica probably at the grocery store or markets. It is the same thing. Check out this link, it gives a lot of good info on what you can do with this wonderful product! (as well as the name of what it is called in Portugal Wink [;)])
http://www.swannysmodels.com/TheCompleteFuture.html
    July 2005
Posted by Barruel on Friday, July 22, 2005 8:18 AM
Thanks for the tip and the link, tho9900.
I think I've seen "Pronto Cera Acrilica (which means Acrylic Wax) in he supermarket.
I will give it a try.
