Grrrr
Grrrr
Posted by Anonymous on Saturday, July 23, 2005 8:46 PM
Angry [:(!]
Now there was a learning curve I could have done without!
The last 2 hours have been spent stripping and cleaning my nice shiny new AB...why?
Copper enamel!!
How in the world are you supposed to spray metalics?
I thinned it down with Humbrol thinners, though it did not want to mix too well.
As soon as I started spraying.....wumpfff plugged AB.
My hands are covered, it took almost half a litre of celulose thinners to clean the brush and the jars.
Lacquer thinner vapour now fills the basement, I have windows open, fans blowing..trying to evacuate the fumes.
Before I started, I searched the forums for any tips, could not see anything so assumed it was all as normal, should have realised that the flakes would block the AB,but still.
So, can I spray metalic copper? or am I reigned to brushing the hull bottom?
Posted by Anonymous on Saturday, July 23, 2005 8:49 PM
Don't mix medias-weren't you spraying enamels , or acrylics yesterday? My advice-use a rattle can for lacquer or metallics. :-)
    January 2004
Posted by MusicCity on Saturday, July 23, 2005 8:50 PM
Lower the pressure. That will allow you to pull the needle farther back to get the same volume of paint flow, thus opening the nozzle a little bit more. Some metallics are difficult to find the right combination for but they usually work fine.
Posted by Anonymous on Saturday, July 23, 2005 8:55 PM
I only ever and allways will use enamels, apart from when I do the black around the stern area, but that will be brushed.
Only thing going through the AB is enamel...ever.
Should the metallic mix ok with the thinners? as quick as I stirred it settled onto the bottom of the jar.
I'll see if I can't pick up a rattle can for the copper/bronze
Posted by Anonymous on Sunday, July 24, 2005 7:13 AM
Vapo-I use a rattle can for lacquers and metallics- much easier, and keep those metallics "well-shaken"-you how quickly they settle. Sorry about the mixed-media mix up-I had you mixed up with someone else.
PS-I keep large cans of common colours on hand from the hardware store (flat white, black, red, yellow and aluminum, etc.).
Posted by Torio on Sunday, July 24, 2005 2:29 PM
I think that learning how to manage enamel-thinner-pressure- nozzle aperture will be harder than with acrylic, peculiarly with metallic pigments as they are huger; but go on, you get it with patience. An alternative could be Gunze metallics or Alclad; with this latter choice, the trick is in the undercoat (priming ). If I remember well, I sprayed Alclad chrome with a 0.15 Evolution without problems. Take your time and make experiences.
Thank you all for coming José
Posted by Anonymous on Sunday, July 24, 2005 2:48 PM
Thank god for marshals on a Sunday! lol Two cans of testers copper metallic, hull bottom drying now.
I fully intend to get to grips with the finer points of ABing, just not on this kit.
I also picked up a tub of acrylic matt black for the intricate work on the back end, already dislike it, it won't stick like enamel, I guess I need to put the model in the dishwasher first,lol
Posted by Anonymous on Monday, July 25, 2005 3:52 PM
So I painted the hull bottom with the testers copper, let it dry, I also painted a bit of scrap plastic as a test bed. Well the copper comes right off when you use a masking tape. So I sprayed the test piece with dull coat, let it dry, and it still comes off with the tape.
What in the world can I do to protect the copper but allow mw to mask it so I can paint the rest of the hull?
Posted by Torio on Monday, July 25, 2005 6:19 PM
I have heard somewhere of using post it sheets as it has a very weak tack and also damp paper ( I think the second one was on http://www.largescaleplanes.com )
Used neither of them personally, now I am experimenting with Micromark Mask it easy mixed with pink acrylic, and a surgeon scalpel, but I think it won't suit your needs.
Posted by Anonymous on Monday, July 25, 2005 8:48 PM
yeh, I just read about the wet newspaper one, I may also try the parafilm, but the surface is very detailed and I really don't want any colour bleed?
I'll do the dullcoat Wednesday after the copper has cured properly.
Posted by Torio on Monday, July 25, 2005 10:24 PM
I've seen a trick in a Kalmbach book (how to use an airbrush ? ) and I had seen the article on one issue. It was about a street car painted in white and yellow. When the white coat was dry, the guy put Tamiya mask AND a clear coat to seal it, then he sprayed the yellow color : chapeau bas, Monsieur, it was very clever.
An alternative if you have intricated detail is liquid mask. I think they are not identical as far as tack is concerned, so trial and error is the rule; apart from the model dedicated range ( Microscale, Micromark, Humbrol, etc...) there is also the drawing gum used in fine arts and some people even use molding latex as a mask, so you can see that your choice is rather wide. You mentioned a clear coat : it could help, but are you sure that you need a dull coat ?
Posted by Anonymous on Monday, July 25, 2005 10:39 PM
what else can I put over metallic copper? the dullcoat is take the shine out of the metallic and protect it at the same time.
Posted by Torio on Tuesday, July 26, 2005 8:09 AM
If you want to take the shine out, it is okay; that is what I meant : do you want to take the shine out ? I think you should look at Model Masters Metalizers or Gunze Metals as it could widen your choice.
