Painting Thin Line Troubles...
Posted by Anonymous on Monday, July 25, 2005 1:04 AM
I have a tricky issue. When I attempt to airbrush a fine line of paint, the paint stops its flow shortly after achieving the line thickness of desire. Once my original sized line stops flowing I can widen the line thickness and the paint flows some more, then stops again. I can repeat this several times all the while the paint line widens little, when in actual fact the airbrush is set for a much thicker line. After this procedure is repeated yay amount, all of a sudden a large burst of paint comes out which is the line thickness that the airbrush is set to.
I usually airbrush with acrylics and my airbrush is a single action piece.
I think the paint is drying inside my airbrush; this is the only thing I can think of that could cause such a problem. Is this correct?
What possible solutions are there to this dilemma, or is there any? Or perhaps Enamels, with the slower drying time are a better paint for the airbrush?
Thank you for any help!
    January 2004
Posted by MusicCity on Monday, July 25, 2005 7:12 AM
Paint drying in and on the tip is, as you said, most likely the problem. Acrylics have a ridiculously fast drying time and that is one of the problems that is common. Adding acrylic retarder to your paint will significantly slow down the drying time and help with that problem. It won't eliminate it but it will help. Also, any time you sit your airbrush down wipe the tip off with a Q-Tip soaked in thinner to remove any buildup there.
Acrylic retarders are available at most art supply stores. Common brand names are Golden, Createx, and Liquitex. Also, Tamiya's thinner contains some retarder.
Posted by Anonymous on Monday, July 25, 2005 2:24 PM
what are you painting? perhaps masking off the thin line would be easier for you?
Posted by Anonymous on Monday, July 25, 2005 5:32 PM
I'm painting camouflage squiggles and lines, if I can mask then I gladly do, but it doesn't do the trick for this.
Thanks for the help, MusicCity! I was oblivious to this "Retarder", that should probably do the trick!
