Paint Problems
Paint Problems
Posted by Anonymous on Tuesday, July 26, 2005 12:03 PM
I use a Badger 175 airbrush and model master paints and floquil railroad paints in the spray cans. The problem shows up when I use metalize and the spray can paint. I push down and back and nothing comes out, then suddenly alot comes out. It only happens with these two types of paint. What's going on here?
    January 2004
Posted by MusicCity on Tuesday, July 26, 2005 12:48 PM
Metallic paints have pigments that are quite large. In many cases this pigment is just too large to pass through some airbrush nozzles. This problem is made worse by airbrushes with a very fine nozzle. In some cases you can remedy the problem by reducing the pressure. Reducing the air pressure allows you to move the needle back further yet maintaining the same volume of paint flow. When the needle is moved back further more of the nozzle is open, thus allowing paints with larger pigments to pass through.
Posted by Anonymous on Tuesday, July 26, 2005 2:25 PM
Thanks MusicCity, I'll give it a try when I get home.
