Cleaning and maintenance for my Iwata hp-cs ?
    March 2004
Posted by plane mad on Tuesday, July 26, 2005 4:53 PM
I recieved my new Iwata hp-cs for my birthday and so far with the small amounts of spraying and testing that i've done i'm quite impressed. My question is whats the best way to safely clean and keep my airbrush maintained.????
So far i've sprayed the appropriate thinner through after each session and i 've even taken it appart and cleaned the needle . I'm just a bit cautious about taking it apart over and over as i don't want to damage anything.Im not use to a conventional airbrush as i've used the aztek a470 for over 5 years and I must say i'm most grateful for the upgrade.
I loook forward to your replys
    July 2003
Posted by saltydog on Tuesday, July 26, 2005 6:43 PM
you gotta mighty fine airbrush in your possession friend.Thumbs Up [tup] own one myself. as far as cleaning and maintenance, you've got it down pretty good, just spray the appropriate thinner through until clean. i wouldn't recommend breaking the brush down but every so often, unless you leave paint in the cup and allow it to dry. purchase some needle juice, or lubricant, from any well known airbrush supplier, and coat your needle with it and put a dab in the moving parts around the trigger area and you should be good to go. good luck, and happy airbrushing. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
    March 2004
Posted by plane mad on Wednesday, July 27, 2005 9:10 AM
Thankyou salty dog for your reply !! I'm really excited about my new airbrush.
    March 2004
Posted by plane mad on Wednesday, July 27, 2005 9:12 AM
Oh yeah i forgot, and i'm not trying to sound greedy or ungratefull here but does anyone else have any tips or something to add, Thanks again!
Posted by mass tactical on Friday, July 29, 2005 10:23 AM
Olsen:
No need to take this ab down after every session. Depending on your paint type, run plenty of solvent and cleaner through, until they are clear, and you should be ready for the next session. You won't damage it by using this technique but I would suggest breaking the ab down after 5 sessions or so. Your ab is excellent and you will not hurt it by overly maintaining it.
Mike M
    March 2004
Posted by plane mad on Friday, July 29, 2005 4:32 PM
Thanks for your reply !
    July 2004
Posted by tho9900 on Friday, July 29, 2005 5:22 PM
I ditto Chris's comments on the needle lube... it really goes a long way to keep paint from adhering to the needle, especially with acrylics!
Posted by kaimuki21 on Friday, July 29, 2005 5:35 PM
What do you take apart when you break down the brush? Do you remove the trigger assembly?
Posted by mass tactical on Saturday, July 30, 2005 11:44 AM
Remove the trigger and the auxilliary spring which is right behind the trigger. After removing these, I take a damp cotton swab, using Windex, and thoroughly clean the trigger area in the body of the airbrush. I then place a little lube on the trigger before replacing it. Depending upon usage I try to do this on a monthly basis.
Mike M
    January 2003
Posted by Jeff Herne on Sunday, July 31, 2005 1:51 AM
Here's part of my airbrush ritual...I have 3 Iwatas btw and I absolutely love 'em.
I only spray acrylics because of my wife's asthma, and I was running through quarts of thinner and cleaner.
I went to the local auto-parts and bought 2 gallons of windshield washer fluid, I think I paid about $2 a gallon. I then bought a package of furnace filter elements (another $2) and stuffed one (I think there's 6 to a pack) into a 2 liter soda bottle (the plastic type).
I cut a hole in the top of the bottle and covered it with tape. When it's time to clean the airbrush, I run lots of windshield washer fluid through it, sprayed into the soda bottle. This prevents the stuff from going everywhere and messing up my spray booth.
I've found the windshield washer fluid really works well. Final step is to go to a department store and find a small ultrasonic cleaner...they're usually in the toothbrush area...used to clean dentures. I paid $30 for mine...if I've used the brush heavily, I drop it into the ultrasonic cleaner overnight and let it soak in windsheild washer fluid. Comes out perfectly clean the next day.
Jeff
    August 2004
Posted by Tankmaster7 on Sunday, July 31, 2005 7:28 PM
Jeff what three Iwatas do you own? Which one do you feel performs the best?
I personally own an hp-bcs. proud owner since the nationals. lol.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    March 2004
Posted by plane mad on Thursday, August 4, 2005 4:08 PM
I'm not quite sure what you mean there Jeft by "dropping the brush in ultrasonic cleaner" Is ultrsonic cleaner somesort of liquid cleaner or a cleaning brush ?
Posted by Torio on Thursday, August 4, 2005 8:04 PM
In this case, an ultrasonic cleaner is a machine with a stainless steel container where you put a liquid medium ( I merely use tap water and a little amount of dish washing solution ) and the things you want to clean. There is an ultrasonic transducer ( in fact, you can find some DIY kits at electronic stores and the transducer is the core of piezo tweeters ) beneath the container which make the liquid medium vibrate and helps the residues ( of paint in this case ) to fall off the soaked parts. You can find one on the Micromark site ( http://www.micromark.com ) but , although I like Micromark a lot, you might find a cheaper ( I don't mean " a cheap ") product elsewhere. I found mine in an electronics store.
Thank you all for coming José
