- Member since
July 2004
Posted by tho9900
on Thursday, July 28, 2005 8:45 PM
like Scott said in the other thread, you shouldn't have to thin it.. is it thick for ya? if it is thick for some off reason you should be able to think it with whatever you thin you other acryics with.. if you dont do acrylics except for the flat try alcohol or Tamiya acrylic thinner.. or MM acrylic thinner... but I've sprayed their semi gloss straight through the old brush with no probs...
