Tamiya masking tape
Tamiya masking tape
Posted by Anonymous on Sunday, July 31, 2005 3:49 PM
What's the deal with this stuff? is it coated with an "anti" stick glue!!Angry [:(!]
Getting mighty piffed at it coming un-stuck halfway through a spray!
Like there is not enough to do, without having to de-bleed edged where the tape lifted!
    January 2004
Posted by MusicCity on Sunday, July 31, 2005 4:19 PM
Best tape going. I have NEVER had paint bleed under Tamiya tape as long as the edges are properly burnished down. You sure you don't have some oil or grease on the surface? (possibly from handling the parts?)
Posted by Anonymous on Sunday, July 31, 2005 4:31 PM
positive. I think because the surface is textured, I don't know, but it's a right royal pain in the arse!
    January 2004
Posted by MusicCity on Sunday, July 31, 2005 4:38 PM
That would certainly do it. Put a line of Future down the edge of the tape. The Future will bleed but it's clear and will seal the edge.
Posted by Anonymous on Monday, August 1, 2005 4:39 AM
Definitely the best tape going - Eduard are swapping their precut masks to this material and that must say something as to the quality! Definitely the textured surface is contributing to your problem but Scott has put you on the right track with the future sealing!
Posted by Anonymous on Tuesday, August 2, 2005 9:46 PM
Are you cutting a new edge before you apply the tape? Even tape kept out of the elements will have dust and other imperfections in the adhesive along the edge, which can allow it to bleed. I learned this the hard way on my R/C cars (Thank goodness for pin-striping tape).
Posted by Anonymous on Tuesday, August 2, 2005 10:11 PM
what I'm doing now is putting the tape down then using liquid mask and cutting along the edge, seems to seal the texture without harming the undercoat.
Thanks chaps
