airbrush compressor
airbrush compressor
Posted by Anonymous on Saturday, August 6, 2005 6:53 AM
do u think this comperssor is any good for airbrushing
clarke Wiz` Mini Air Compressor
heres the spec's
Quiet operation oil free diaphragm compressor with aluminium body
Maintenance free
Built in carry handle, very light & easy to transport
1.58cfm air displacement
2.8 Bar maximum working pressure
Includes pressure gauge
99 Watt, 230v motor
    July 2004
Posted by tho9900 on Saturday, August 6, 2005 7:08 AM
Martin - sounds like it will work... hard to say without actually seeing it but sounds like a typical compressor like the Paasche series..
correction, I just did a google search and saw it, that should do the trick for you... you'll need a moisture trap and maybe the connector (male to male) to screw the airbrush hose on to but the compressor itself is almost identical to the Paasche Dxxx series compressors.
Posted by Anonymous on Saturday, August 6, 2005 7:26 AM
thanks for the info tho9900
