How to refurbish old airbrush.
Posted by Anonymous on Tuesday, August 9, 2005 1:31 PM
I have an OLD Badger 350 which has not been used in years. It really took a beating at one point, paint was spilled all over it, it was dowsed with varsol, etc.
It seems to work fine in terms of the air valve but I want to clean it up, especially the paint tips/needles. They've got reminants of paint in them, either acrylic or enamel (probably a little of both).
Any advice on magic cleaning fluids etc?
Posted by Torio on Tuesday, August 9, 2005 2:39 PM
It seems that you are ready for the "Magical Ultrasonic Tour" :
Pick an ultrasonic cleaner, fill it with adequate cleaning solution, put the airbrush in it, switch it on and the magic appears ! You can eventually do it several times. If you are short of special solution, water with a LITTLE amount of dishwasher solution will do the trick.
There are cheaper ways but this one is sooo smart...
Thank you all for coming José
