How to apply clear
    January 2003
How to apply clear
Posted by lavony on Tuesday, August 16, 2005 6:57 AM
Hello I tried to apply flat clear layer(Tamia) with my airbrush but it didn't came good. My question is : If I'll do it with a brush, will it leave signs of the brush?
what preesure should I use (with the AB)?
Thanks
Posted by Anonymous on Tuesday, August 16, 2005 10:11 PM
applying with the brush will leave stroke marks (at least in my experience). no tips on pressure, though.
    September 2004
Posted by giobosco on Friday, August 19, 2005 6:41 AM
Hi there,
To be honest with you, and I don't know if other guys in here agree, but my personal experience, I usually dilute the flat with a bit of tamiya acrylic thinner, and then I spray at moderate pressure, so that I get an even cover, but also a strongish flow, it is a bit of trial and error, but thinning definitely helps with the flow. Varnishes are quite thick to start with.
All the best
GB
    August 2004
Posted by Thehannaman2 on Saturday, August 20, 2005 9:47 AM
You can also thin it with good old fashioned (and cheaper Wink [;)] ) rubbing alcohol.
Justen
"The distance between genius and insanity is measured only by success."
Member IPMS Niagara Frontier. "The BuffCon Boys."
IPMSUSA Member 45680
