Another primer question...
Posted by Anonymous on Tuesday, August 16, 2005 9:15 AM
Disapprove [V]Within the last year, I've gotten back into modeling and have started using an Air Brush. I use mostly Model Master Acryl's and some Tamaiya Acryl's. On my last build, i tries to mask off an area only to have the underlying paint chip off with the masking tape (Tamaiya tape). The question is, would a primer coat help this or would it pull off also?
    January 2004
Posted by MusicCity on Tuesday, August 16, 2005 11:25 AM
Two things are an an absolute must when using acrylics:
1) CLEAN THE PARTS! Acrylics to not adhere to plastic like enamel or laquer, nor do they have the solents in them to dissolve any oil or grease on the parts. The parts MUST be free of oil or grease (including that from your hands) or the adhesion is going to be virtually nil.
2) PRIME THE PARTS. If you are going to mask over acrylic, prime the parts with a good quality enamel or laquer primer or you run the risk of the paint pulling up.
