To keep it stable, shake the bottle or turn it over once a month. This will work for about nine months and then it will start to seperate. When that happens nothing will help to save the paint. If you can use it prior to then, you will have no problem.
Berny
Phormer Phantom Phixer
On the bench
TF-102A Delta Dagger, 32nd FIS, 54-1370, 1/48 scale. Monogram Pro Modeler with C&H conversion.
Tamiya F-4D Phantom II, 13th TFS, 66-8711, 1/32 scale. F-4 Phantom Group Build.
