Anthem problem
Anthem problem
Posted by Anonymous on Friday, August 19, 2005 2:37 PM
Hi guys. My Anthem has started binding at the trigger when it's pressed down (air on). I've taken it apart and reassembled it, lubed it, have taken ultra fine sandpaper to even out any burrs, but it still persist. Has anyone else come across this problem or am I looking at a send in to Badger? If it's sent in, how long is turn around usually? Thanks.
E
    January 2004
Posted by MusicCity on Friday, August 19, 2005 2:44 PM
It's crud in the air valve. It happens from time to time. Not difficult to take apart and clean though.
Unscrew the valve from the airbrush body. You may have to hold the air valve with pliers to loosen it.
There is a hole in the bottom of the air valve that an Allen wrench fits into. Use an Allen wrench of the proper size, and while holding the air valve body with pliers (there is a knurled ring around the body that works well) unscrew the fitting in the bottom of the valve
**CAUTION!!!** The valve has a very small spring and valve stem in side. Be careful and do not loose them!
The valve stem has a captive o-ring on it. Carefully clean it but avoid getting solvents on the o-ring. The body, spring, and bottom cap can be cleaned with laquer thinner or other strong solvent.
Put a little Vaseline or airbrush lube on the o-ring and valve stem, reassemble, and it should be good as new.
Edit ... It must also be contagious. I got home and my Omni was doing the exact same thing Tongue [:P]
Posted by Anonymous on Sunday, August 21, 2005 7:34 PM
Thanks Scott, it worked liked a charm. The action is as smooth as corn silk ( politically correct )! I was so impressed, I stripped two other brushes to make them as smooth. If you have any other performance tips, please pass them on.
E
    January 2004
Posted by MusicCity on Sunday, August 21, 2005 8:12 PM
That's about the only trick I have. I don't even have an Anthem but all the Badger brushes use the same air valve. It's an easy fix and really does make them feel a lot smoother if it's cleaned out from time to time. Glad it took care of it for you.
