To Prime......or Not to Prime.....that is the question?
    May 2005
Posted by IceDragon122 on Friday, August 19, 2005 11:32 PM
Well I use Tamiya Gray Primer in a rattle can......and am not liking the results......
I was wondering if i could use Model Master Primer and use an airbrush.....to get more control.....and if it is possible to use Model Master....
What do i thin it with? and can it go underneath a layer of acrylic paint. (meaning I prime the model then airbrush over it Tamiya Acrylics)
Can anyone lend me thier keys of advice?
-Brian
    January 2004
Posted by ua0124 on Friday, August 19, 2005 11:45 PM
Sorry to hear about your results. What kind of results are you getting?
I have used different primers, from MM Custom Lacquer Gray Primer to MM Acryl primer. So far I have achieved some postive results. All I use for painting purposes is acrylic paints and I have had no trouble when I spray over the primer. As for thinning I do not need to. I get good results.
Ernie If I can not do something about a problem, it's not my problem; it is a fact of life...
Posted by Anonymous on Saturday, August 20, 2005 5:43 AM
What was wrong with the Tamiya primer?
    May 2003
Posted by qmiester on Saturday, August 20, 2005 8:45 AM
Over the years, I've had very good luck with standard automotive grey paint in a spray can. With a little practice, you can get a good covering without obliturating the small details. Just make sure it's enamel primer, not laquer. It's cheaper than modeling primers (let's see you prime a dozen or so 1/72 aircraft out of that little can of modeling primer). I live in a town of 3,000 and can get auto primer in the hardware store, lumber yard, dime store and the $1 General Store in grey, black and red. Give it a try.
Quincy
    May 2005
Posted by IceDragon122 on Saturday, August 20, 2005 9:53 AM
Thx for the idea's.....ill try tamiya once more....
-Brian
Posted by Anonymous on Saturday, August 20, 2005 12:17 PM
Does anyone know what Tamiya's grey primer is? Lacquer? Enamel? Acrylic?
    July 2004
Posted by tho9900 on Saturday, August 20, 2005 2:14 PM
It's enamel...
I use Krylon white or Tamiya grey for my priming, used MM before but figured out Acrylic on top of acrylic might not be enough of a bond... I am sure they make an enamel one as well but only seen acrylic here...
Posted by Anonymous on Saturday, August 20, 2005 3:33 PM
How bad are the fumes from Tamiya grey primer aerosol?
Posted by Anonymous on Monday, August 22, 2005 1:08 AM
Very bad fumes, I thought it is lacquer not enamel. I've got floquil enamel grey primer and thinner to try in my AB, you should get a much better coverage priming with the AB especially in those difficult to reach bits.
    July 2004
Posted by tho9900 on Monday, August 22, 2005 6:59 AM
yeah the fumes are pretty bad Boceli... and Tamiya is lacquer I think, the can I was thinking about at the time was MM..
