swanny's website
swanny's website
Posted by Anonymous on Saturday, August 20, 2005 5:45 AM
I recently read this on swanny's website
"Future does produce a glossy finish so many modelers will introduce a flattening material or only use it as a pre-decal sealer. If you wish to use flattened Future as a final coat here are a couple of suggested ratios of Tamiya flat base for different effects:
1 part flat base to 3 parts Future = very flat
1 part flat base to 10 parts Future = flat
1 part flat base to 15 parts Future = satin
If you get too much of anybody's flat base on the surface of your model you run the risk of making it all go white. No thinning is required just make sure it is well mixed. "
i live in the uk, what is flat base and where can i get it
anyway, swanny's site is great, now i understand weathering
Posted by Anonymous on Saturday, August 20, 2005 7:03 AM
Flat Base is a flattening additive made by Tamiya. Its number is XF-21.
Posted by Anonymous on Saturday, August 20, 2005 7:36 AM
thank you
i'll keep an eye out
    August 2004
Posted by Thehannaman2 on Saturday, August 20, 2005 9:40 AM
Note: you can use any type of acrylic based flat clear.
Justen
"The distance between genius and insanity is measured only by success."
Member IPMS Niagara Frontier. "The BuffCon Boys."
IPMSUSA Member 45680
