QUOTE: Do you guys know what the freezing temp of paint is?
Glue for that matter too. |
In understand in Minnesota there are only 3 months in a year: June, July, and Winter.
Not to worry about freezing paints. Organic solvents as a rule have very low freezing points. Acetone, Methyl ethyl ketone (MEK), and Toluene (enamel and lacquer paint-type solvents) all have freezing points in the range of about -123 to -139 degrees F. (I really don't think it gets that cold anywhere on the planet, much less Minnesota). MEK is also the primary constituent in Testor's liquid cement...
Alcohols, like Isopropyl, and many of the glycol ethers used in acrylic paint production have freezing points of around -125 degrees F.
The one thing you will have to take into consideration will be considerably longer drying times.
One way to help beat the cold is to place your paints and solvents (thinners) in a bath of warm (Make SURE it's warm, NOT hot!) water for 20 minutes or so before you're ready to paint. This method also works really well for rattle cans. But be careful: Once warmed, the paints will come out of the nozzle a little quicker and thinner than normal. Spray at increased distances to keep paint from running.
Hope this helps some.
Gip Winecoff
