MCW lacquer Question
    November 2003
Posted by rudedog on Thursday, August 25, 2005 3:01 PM
I just sprayed a model car body,using MCW italian red for the 1st time.I am pleased with the quality & ease of coating,But it turned very dull upon drying.I used Tamiya Laq. primer,& the finish is smooth without eggshell.Are all lacquers dull like this ?What can I do to rescue what is a basically good paintjob ?
"...That's an order,not a debate topic , Sergeant Rudzik..."
Moderator
Posted by Matthew Usher on Thursday, August 25, 2005 4:17 PM
MCW lacquers usually need to be polished after they're applied. MCW sells a liquid polish called "Buff Ez" (I think) that will bring it up to a high gloss.
You might also try Tamiya's polish or Novus No. 2 plastic polish.
Matt Usher @ FineScale Modeler
I used MCW's McLaren Orange on my Accurate Miniatures kit:
    November 2003
Posted by rudedog on Thursday, August 25, 2005 6:01 PM
Thanks Matthew,if I've been a good boy,my 72 SS ElCamino will respond to your hint of polishing.I'm guessing it wouldn't hurt to give it 48 hours to dry completely.I love this site !!!
    May 2003
Posted by qmiester on Friday, August 26, 2005 8:37 AM
You might check the thinner - a while back I painted a repair I did to an airframe and the gloss white dried to a dull finish and we couldn't understand it. DuPont Enamel, Dupont Enamel Reducer - then we noticed it was Acrylic Enamel reducer - got the proper Enamel Reducer, sanded down and reshot surface. And the resulting coat dried Gloss. You may have the same problem.
Quincy
