Maskol....how to use it and where to get it?
    August 2004
Posted by cj95 on Monday, August 29, 2005 2:50 AM
(not sure if this goes in paint or techniques....sorry)
I recently ran across a mention of this item for masking off hard-line camoflague, and am wondering if anybody has tips on how this is used and things to watch out for.
-How easy it it to remove afterwards....(how is this done)
-Good for armor and aircraft?
-Used with only certain paints?
-does any paint leech through?
-where can I buy it?
-anything else I missed?Wink [;)]
Thanks
==Chris
Posted by Anonymous on Monday, August 29, 2005 3:15 AM
Maskol is a liquid mask that should be readily available at any hobby store that stocks the Humbrol range of paints. There are others including Gunze masking Neo-Sol (I think that's correct) and some people choose to use artists liquid masks such as those made by Daler and Rowney. This later company make a liquid mask specifically for use with acryllic paints. I use the Maskol with enamels but see no reason why it couldn't be used with acryllic paints. I do not use it as a sole masking agent but rather to fill in areas already delineated by masking tape (Tamiya). In this regard it is easy to remove as the tape gives you something to grab on to. I haven't had paint bleed but do apply quite a thick layer. The instructions say remove within 3 days but it has been my experience that the "mask" can be left pretty much indefinitely. Clean up with water. One way to use liquid masks on armor is to flick a random pattern over a basecoat then apply the top coat (say winter finish) before removing the mask (use a latex glove to give some grip and "wipe" the mask off to reveal a chipped effect). The pic below doesn't show it very well as I have painted but the tape/blu tack masks on top of the forward fuselage have been sealed with Humbrol Maskol.
    September 2004
Posted by Borg R3-MC0 on Monday, August 29, 2005 3:36 AM
A warning about maskol, you cannot use it on acrylics (or future). Maskol contains ammonia and this will damage the acrylic.
You can use is safely and easely on enamels.
Posted by Anonymous on Monday, August 29, 2005 3:41 AM
Thanks Remcogrob that's a lesson learnt - good job I use enamels then eh!! LOL. What about future over dried Maskol (I have done this without problems) - what are your thoughts?
    August 2004
Posted by cj95 on Monday, August 29, 2005 1:58 PM
Ok some good tips here...I think I definately need to add this to my toolkit.
Question just to clarify.......to remove, you wash it off with water? --Or did I misunderstand you?
Also, I should not use it as at the edge of my paint pattern (or whatever) ie....I can't 'paint' a camo pattern over a basecoat and then overspray it, expecting to wash off a perfect camo pattern?
Thanks for the tips.
    December 2004
Posted by Gilmund on Monday, August 29, 2005 6:38 PM
I think he meant that the eventuall residue could be cleaned with water. The maskol itself tries into a latex-like material and is easy to just peel off.
- Johan Byberg -</font id="blue"> "Who´s the most foolish, the fool or the fool who follows?"</font id="size1">
Posted by Anonymous on Monday, August 29, 2005 7:14 PM
splatter effect?? thish shounds easier than the ole salt chipping. any comments???
Posted by Anonymous on Monday, August 29, 2005 9:16 PM
Sorry if I mislead you: by cleanup I meant cleanup of the brush you use to apply the mask to the model!! For removal of the mask on the model you just peel it off and it doesn't leave any residue to my mind. You could use it to edge a camo pattern if you wish but I choose not to personally.
Posted by Anonymous on Monday, August 29, 2005 9:19 PM
Where I have seen this in magazine articles the modellers have used the more liquid Gunze product and either truly splattered the mask onto the model off a toothbrush, or applied it carefully but randomly with a small piece of sponge. The finished result has always looked excellent and I am eager to try it myself sometime.
    August 2004
Posted by cj95 on Tuesday, August 30, 2005 2:13 AM
Sounds great guys.....
I'll give her a go
Big Smile [:D]Big Smile [:D]
    August 2003
Posted by tweety1 on Tuesday, August 30, 2005 9:16 AM
I have used Maskol for many years now and have never had a problem with it on acrylics, which is my choice of paint for 99% of my modeling.
I also haven't had a problem with it on Future, but I don't leave it on for any more than a couple of days.
It dries to a rubbery finish, like latex, and paint won't bleed under, never has for me.
As for splatter effect, I use a small piece of foam, dip it LIGHTLY in Maskol, and gently dab it onto the model.
After a few minutes it has dried, then I spray as required and remove the Maskol with a latex glove.
Great stuff. and definately worth putting in the toolbox.
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
