Airbrush/Compressor setup?
Posted by Anonymous on Wednesday, August 31, 2005 6:47 PM
Hi, guys. Just got my new Badger Crescendo airbrush kit. I also picked up a slightly used Paasche D500 compressor off eBay for $28. My question is: what else will I need to have a complete setup for airbrushing? Will I need an air regulator since this compressor is made for airbrushing and not a larger compressor that's not made for the hobby? Oh, yeah, and what about a moisture trap?
Sorry for all the questions, but I want to get started practicing right away. Thanks for any help you guys can give!
JohnSmile [:)]
    July 2004
Posted by tho9900 on Wednesday, August 31, 2005 8:35 PM
John - congratulations! The 175 is a good airbrush... I have that one as well as the Badger 155 and Iwata HP-CR and after the HP-CR I use the 175 second most.
You'll need a regulator at the least, you can get one at most hardware stores and even Wal Mart if you have one near. They have larger graduations to the markings (from 2.5 to 5psi per mark) than the hobby style ones but it still works, you might want to check out a real hobby regulator though as I think eventually you will want more control over how much PSI you use (the marks are 1psi increments). If you have a Hobby Lobby nearby they have them (complete with built in water trap) for about $40 I believe. The ones at the hardware stores are about $25 with $15 or so for a watertrap so they are about the same price.
Speaking of water traps, unless you live in a rather dry area (like New Mexico or such) you'll want to get one. Nothin ruins a good paint job like a stray drop of water coming from your airbrush.
Besides that, just paint and something to paint it on as well as the appropriate thinner and you'll be airbrushing away!!!
Good luck to you and if you need anything else dont be afraid to ask!!!
    July 2004
Posted by tho9900 on Wednesday, August 31, 2005 8:36 PM
oh yeah, at the store the water trap I mentioned is most commonly referred to as a moisture trap or air filter with moisture trap.
Posted by Anonymous on Wednesday, August 31, 2005 9:15 PM
Thanks a lot, Tom! I really appreciate the advice.
By the way, how does the 175 do as far as fine detail airbrushing? I eventually want to do some of the German WWII aircraft, and I know they have some pretty complex paint schemes.
Thanks again!
John
Posted by MikeV on Wednesday, August 31, 2005 9:27 PM
If possible I would try and find a small airtank or convert a small fire extinguisher bottle and put it between the airbrush and the compressor.
It will smooth out the airflow because those diaphragm compressors pulsate the air quite a bit.
Posted by Anonymous on Wednesday, August 31, 2005 11:28 PM
Hi, guys - new here. I'm in the process of setting up a couple of airbrush rigs for my sons, was wondering about compressor recommendations that won't break the bank. I got my first airbrush probably at about age 13, my dad built up an old freezer compressor, freon bottle for a tank, with a dryer and regulator for me. The old compressor is long gone, but I've still got the freon bottle!
Do any of you have any experience with the Campbell Hausfeld 2gal tank-mounted diaphram compressor that I could pick up at Walmart for about 70 bucks? I know I'd need a dryer, and possibly a regulator with finer control, or at least a lower pressure gauge, but other than that, what do you think?
Thanks!
