To expand a bit on what Simon said, there is a reason that propellant cans are so frustrating. The propellant, whatever it is, isn't like a can of spray paint. It comes out cold. Very cold. After a few minutes of use ice will start to form on the can. As that happens the pressure starts to drop so you have to compensate by opening the air valve. Put your airbrush down for a few minutes, the can warms back up, the pressure builds back up, and on your next spray you get a lot more pressure and a lot more paint. You can help alleviate these problems by sitting the propellant can in a pan of warm (NOT hot!) water. It will not eliminate the problem but it will help.
Save up and get a compressor. Even a cheap one is better than propellant cans. Alternatively consider a tank of compressed nitrogen or carbon dioxide. Inexpensive an perfectly silent.
