Scott, what kind of acrylic retarder? If Tamiya thinner includes the retarder, could I mix that with the Isopropyl? If so, at what ratio? Could I use 99% Isopropyl mixed with distilled water (for some reason I have two nearly full bottles...) to create the 70% solution? I knew I should have paid more attention during chemistry, but Susie had to go and wear that sweater!
Right now I'm using the Tamiya thinner and acrylics, and tonight was the first time I actually used the AB in anger. I only painted the kettenkraftrad for my Do 335A, but I must say I'm hooked on ABs! Wow, what an improvement! Smooth and even coverage, and I used a much smaller amount of paint, to boot!
