medical compressor (nebulizer) for airbrush?
Posted by Anonymous on Friday, September 2, 2005 10:26 PM
Can any of you with experience using this type of compressor for airbrush painting comment on the usefulness, etc? It seems as if they're available for pretty reasonable prices here and there, and was wondering how well they'd work out for a couple of young teenage budding modelers.
Thanks!
Gordon
    January 2004
Posted by MusicCity on Saturday, September 3, 2005 5:51 AM
Never used one myself but an airbrush isn't picky about how it gets its air. As long as you can 1) Get the airbrush connected with no leaks, 2) Get enough volume and pressure, and 3) Control the pressure in some way it see no reason why it wouldn't work. Depending on your definition of "Reasonable Price" you might be able to get a more suitable compressor in the same price range.
Posted by Anonymous on Saturday, September 3, 2005 9:36 AM
well, "reasonable" in this case is around 20 bucks shipped for used units on ebay.. not a bad price! I'm also thinking of a diaphram type compressor w/2gal tank like the campbell hausfeld you can get at walmart for about 70 bucks for each of the boys, then add a secondary filter/regulator that's got a more appropriate pressure range for AB work instead of the 0-150 that typically comes on one of those.
Thanks for the reply!
Posted by Anonymous on Saturday, September 3, 2005 3:10 PM
Dood I am using exactly that for my airbrush. What you need to do is make sure it's still able to make enough pressure. Those compressors are not good to plug direclty in since they pulse and ur airbrush won't be regular.
What i did is buy an air tank from the hardware store and I adapted a hose to it. I also bought a pressure regulator and water recuperator from a specialized shop and i fitted that to the output. Get the 10 gal tank if u can it's not really expensive.
The compressor makes around 28 psi and I use from 10 to 20 psi to paint. So as long as you keep your tank over 20 u will not get pulses.
You will also notice that the compressor is not very strong and if under pressure it will not start. What you need is to but a valve somewhere between the compressor Output and the air tank input to be able to relieve the pressure in the hose when you want to start it. I guess I could get some pictures of the thing but i'm pretty busy these days but i'll try.
E-mail me if you have questions.
    May 2010
Posted by Mike Deane on Thursday, May 20, 2010 2:15 PM
Would you please take some pictures?
