Badger "Propel"+ Badger "can regulator"+Iwata HP-CR?
Posted by Anonymous on Sunday, September 4, 2005 5:56 PM
It seems that my iwata braided hose won't even come close to fitting the badger can regulator that I purchased the other day. I am using an Iwata 10 foot braided hose, but I am wondering if I should just switch to a vinyl badger hose for now. It would fit the regulator for can airbrushing but would it fit the Iwata airbrush?
I need to know if it will work, and yes I already know that I should buy an aircompressor.
Posted by Torio on Sunday, September 4, 2005 7:53 PM
I own a number of airbrushes and equipped them all with quick connect so to use only one kind of airhose; it is a transparent vinyl type of 5.6 mm diameter and it feeds perfectly all the airbrushes; on the other hand, if you are only going to use one airbrush, it seems that a great deal of adaptors exist so you could probably use you hose with your regulator, as far as I remember, the Iwata diameter on the compressor/can side and the regulator diameter are very common in the airbrush world, so it should not be difficult; the most quoted shops ( Dixie, Coast, Bear air) most probably stock them
Thank you all for coming José
    August 2004
Posted by Tankmaster7 on Sunday, September 4, 2005 9:08 PM
my badger hose does NOT fit my iwata airbrush by a long shot. just thought id mention...
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by Torio on Monday, September 5, 2005 4:37 AM
No, chap, what I mean is that it is most probable you"ll find adaptors on the other end as the air supply end tends to have a most common diameter. On the airbrush side, every maker has his own gauge and this is very difficult to manage
