MikeV and the 3155 Hybrid
Posted by Anonymous on Wednesday, September 7, 2005 10:38 PM
Mike, Tom ( tho9900) and I had a sidebar conversation recently. I had a theory about the 175 Crescendo's fine needle and head assembly. Is it possible to spray as fine a line with it as a 3155 Hybrid since they use the same head assembly. Or does the Hybrid use a finer needle taper with the Vega needle ( or is it Omni )?
E
Posted by MikeV on Wednesday, September 7, 2005 11:30 PM
I would have to look into it furthur.
They use similar needle tapers so they are probably close.
Of course it all depends on the finger operating it also. Wink [;)]
Posted by Anonymous on Thursday, September 8, 2005 10:53 AM
Thanks Mike. Do you find that you have to thin your paint more with your Hybrid than with your Anthem or do you use about the same consistency? The reason I ask is that I remember that you told Tanky that the needle taper of the Hybrid would more closely match the Eclipse than the Anthem, so maybe thinner/paint ratio and pressure adjustment would produce a nice fine line similar to an Eclipse. I've got Guard drill this weekend so I'll try to do some test next weekend. See ya and take care.
E
P.S. - If anyone else has experience with this, please feel free to jump in!
