Aztek airbrush question
    February 2004
Posted by In The Woods on Tuesday, September 13, 2005 3:51 PM
Hello, all:
In my Aztek airbrush parts, I have a two-part color cup. The whole thing reminds me of a double-boiler arrangement for the stove. It is made up of a black bottom section into which the air supply feeds, and a light gray upper section, which has a slot in the bottom, which looks as if it holds the paint. Has anyone used this gizmo, and if so, what is its use?
Thanks to all.
Steve Mack
Never put temptation in the way of a weak soul. Mrs. Dinkins' First Precept
    April 2005
Posted by cruichin on Tuesday, September 13, 2005 4:49 PM
I think you have the cup upside down. The black section is a top for the cup to help prevent spills when using. The bottom slot fits into the AB, and the air supply is through the AB, not the cup.
Posted by Torio on Tuesday, September 13, 2005 5:12 PM
As far as I remember, those were the first cups, before the white models which are one piece only; you'll notice that paint gets out of the bottom of the white cup; let's say it's gravity feed; the grey and black cups work differently : paint goes outside the inside cup into a thin "tunnel" along the outside cup and into the outgoing tube to the airbrush; I should call it semi-aspiration feed; I don't remember of these cups being better or worse than the white ones; maybe they were intended to regulate paint flow, but I never saw big difference; apart from the extra cleaning, which is very little, you can use them with confidence.
Thank you all for coming José
