- Member since
June 2005
QUOTE: Originally posted by Ralph Marshall
I got a fairly cheap compressor from Sears when they were having a sale - I got one with a 5 gallon tank (150PSI) and regulated output for about $150, including a set of accessories. This way I can pump the tank up to about 100PSI, turn it off and spray in peace and quiet. I have yet to run the tank down in a session, and it only takes 5-10 minutes to pump it up, during which time I'm getting set up. Just be sure to empty the tank after you use it so that the water doesn't eventually rust out the tank and cause a spectacular failure.
I have not gotten a moisture trap yet, and so far I haven't needed it. Given that I've been using it in the humid NC summer that surprised me, but I have yet to have it blow water through the airbrush.
I have one like that. mines a pancake. I turn it on until it gets to about 80 psi and turn it off, before I spray every day.
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly."
No wait, that's not it.
