Favorite masking material
    July 2005
Posted by clairnet_person on Friday, September 16, 2005 8:32 PM
Hi there
I'd like to know what kind of sutff you like to use for masking the most?
Just like to get your opinion!!!Smile [:)]
Current builds: Monogram P-40B Revell F-15E
    July 2004
Posted by tho9900 on Friday, September 16, 2005 10:17 PM
I use three types of tape usually... blue painters tape for large areas... i.e. masking a demarcation line on a fuselage... I use MM tape for really sharp non-complex curves.. and for canopies or anything with a lot of angles or curves I use Tamiya tape.. it is softer and conforms better to curves... it works great for canopies for the same reasons...
Posted by ABARNE on Saturday, September 17, 2005 4:29 AM
I'm basically with tho9900. 3M Blue painter's tape for large coverage and Tamiya yellow for making sharp lines, conforming to curves, canopies, etc. 3M Blue is fairly inexpensive, peels off nicely with no residue. Tamiya tape is a lot more expensive, but is very low tack, while at the same time quite bleed resistant. It is also extremely thin so it avoids build up at the edges. With careful us of Tamiya tape where needed and 3M Blue otherwise, its not that expensive.
Andy
    January 2004
Posted by MusicCity on Saturday, September 17, 2005 6:20 AM
Same for me. Tamiya tape for critical areas, blue painters tape for general coverage. Post-It notes and pieces of plastic bags to control overspray.
Posted by mass tactical on Saturday, September 17, 2005 9:58 AM
Black electrical tape also has its uses. Cut thin, it conforms to curved surfaces where other tapes may not.
Mike M
    January 2003
Posted by plasticmod992 on Monday, September 19, 2005 1:59 AM
Pretty much the same for me, like those above, however; for canopies I use Bare Metal Foil *(BMF) and Parafilm M. For general masking, I mostly use Tamiya tape.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by Anonymous on Monday, September 19, 2005 7:01 PM
Maskol
Posted by Anonymous on Tuesday, September 20, 2005 8:05 AM
i use sticky tac, its kind of like reusable clay. like a kneaded eraser for artists who draw with pencils. conforms the way you want it to,plus it doesnt destroy paint jobs when you place it on paint!Cool [8D]
Posted by Anonymous on Tuesday, September 20, 2005 2:33 PM
I use 3M Blue painters tape, Model Master tape, Micro Mask with food coloring added, and Silly Putty.
Posted by berny13 on Tuesday, September 20, 2005 8:51 PM
Plane old masking tape 90% of the time. For clear parts I use Scotch Clear tape.
Berny
 Phormer Phantom Phixer
On the bench
Posted by Anonymous on Wednesday, September 21, 2005 9:14 AM
kamoi tape....yellow color, low tack, easy to cut and work with.
