Selecting a "QUITE" multi-purpose air compressor. Any suggestions?
    September 2005
Posted by Hocking on Friday, September 16, 2005 10:56 PM
I am looking to purchase an air compressor in the next few days. I am hoping to be able to find something for less than $150 that is capable of not only running my air brush I just ordered, but also capable of blowing up tires and other things like that. Something that can operate at around 55psi maximum.
But, more importantly, I want this thing to be small and very very quite. This is more important than the things mentioned above. I am just trying to avoid spending $150 for an air compressor that I can only use to run my airbrush. I guess I will do this if I have to in order to get something quite, but I hope I can find something quite that can be used for other purposes also.
I would also like to know if a CO2 tank may be the way to go. How much money on average do these things cost to rent/lease? How much do they cost to buy? How much to refill? How long does a full tank usually last?
Any help, comments, or suggestions would be greatly appreciated.
Posted by MikeV on Friday, September 16, 2005 11:41 PM
The words "quiet" and "cheap" do not apply to a compressor that will do what you want.
I would suggest either getting an industrial type compressor and running a long airhose to where you paint so that you don't have to hear it.
Either that or buy one only for airbrusing.
CO2 is also a good alternative but comes out to more money in the long run.
A 20 lb CO2 tank will last you a long time for modeling.
