Ok, where do I go now ?
    March 2004
Posted by DanCooper on Saturday, September 17, 2005 8:07 AM
My beloved wife has started building her Tamiya Nismo (Skyline), but something went terrebly wrong with the paintjob (Tamiya spraycans), for some reason, the topcoat (TS-36 Fluo Red) reacted with the Tamiya Primer.
I've read about using breadfluid to strip the paint, so what's next :
- do we put her body in a bath of breakfluid overnight ?
or
- do we use tissue and cotton to apply the breakfluid ?
On the bench : Revell's 1/125 RV Calypso
Posted by Anonymous on Saturday, September 17, 2005 8:30 AM
Dan-if the paint is fresh just soaking in thinner should do (unless it's lacquer). Paint is a complex thing-maybe the topcoat paint was too hot, or the primer not dry enough. Once stripped I would try other paints. I buy my primers at auto shops-they're cheaper and more durable.
    January 2004
Posted by MusicCity on Saturday, September 17, 2005 8:59 AM
Tamiya primer is a laquer. I don't know about their color sprays though. I would **NOT** recommend soaking the model in laquer thinner. It will dissolve the plastic over time.
Here is a link to some stripping ideas on Bonedigger's site:
http://www.bonediggers.com/1-3/strip/strip.html
I personally prefer Castrol Super Clean but it doesn't do a very good job on laquers, at least not in my experience.
Personally, I think I'd first try to smooth the surface with some very fine steel wool or ScothGuard pads and then just spray another coat of primer. Worst case you lose some surface detail but if you are careful with the sanding that should be minimal.
Posted by HeavyArty on Saturday, September 17, 2005 9:38 AM
Best stripper for lacquer and enamel paints is spray oven cleaner. Make sure it is not the odor free weak stuff, use full strength Easy-Off or similar. Spray the model down with it, then seal it up in a ziplock bag or tupperware container for 24 hours. Remove and rinse off with water. You may need to take an old toothbrush and scrub a little in recessed areas to remove all the paint. Works great though.
Posted by MikeV on Saturday, September 17, 2005 6:09 PM
No, oven cleaners are second best.
Castrol Super Clean beats them all hands down and it is non toxic like brake fluid is.
Brake fluid is dangerous stuff and I do not recommend you use it.
Get it in your eyes and you can forget about modeling again.
