Melted Plastic
Melted Plastic
Posted by Anonymous on Sunday, September 18, 2005 12:01 PM
I used my Aztek this morning to do some painting. I use MM Metalizer gun metal. After painting I cleaned it out with lacquer thinner till no paint could be seen on the microbrushes I used to clean it. Then I washed the whole thing with soapy water and let it dry. When I went to apply the sealer, the airbrush wouldn't blow. No air was coming out. I took the airbrush apart and found that lacquer thinner had sneaked into the back of the airbrush and melted pretty much everything but the metal and the body. I don't know how it managed to get back there, mainly since the soapy water bath didn't get back into the airbrush. What a waste of money. Now I have no airbrush, and more importantly, no money. I'm looking into buying a cheap airbrush that is easy to clean. I only use airbrushes for large to medium coverage and not fine lines.
I'm thinking of purchasing this one:
http://www.bearair.com/prodinfo.asp?number=100022
or this one:
http://www.bearair.com/prodinfo.asp?number=100182
They are both cheap, but I have read on many sites that the Vega is really easy to clean. Of course, that's what Aztek says. Iwatas are out of my price range.
    July 2004
Posted by tho9900 on Sunday, September 18, 2005 12:54 PM
Ryan - I own the 175 Crescendo and it is a good brush.. (it's what I abandoned my Aztec for) however for about the same prive the 155 Anthem might fit your needs more. What type of models do you build most? The 175 is better suited to overall coverage, it can do some detail work but the 155 is better at it. If you do a lot of armor the 175 will do you more than fine, but if you do 1/48 aircraft and such then another look at the 155 might be worth it as it does both moderate coverage and decent detail...
I haven't used the Vega although it looks to be a good brush... maybe Mike can give better feedback on that one..
Good luck!!!
    August 2004
Posted by Tankmaster7 on Sunday, September 18, 2005 5:39 PM
Iwatas are not much more expensive than what you have listed.
http://www.dixieart.com/Iwata_Revolution_Airbrushes.html
Iwatas for 65. No shipping charge.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
Posted by Anonymous on Sunday, September 18, 2005 5:50 PM
Thanks for the suggestion Tank, but I don't want a gravity feed brush, the ones I listed are complete deluxe sets and not just the airbrush with a few accesorries, and I have had bad service from Dixie Art. If money wasn't a factor, I still would rather have a Badger over an Iwata.
    January 2004
Posted by MusicCity on Sunday, September 18, 2005 5:52 PM
QUOTE: If money wasn't a factor, I still would rather have a Badger over an Iwata.
A man after my own heart Tongue [:P]
