painting very fine PE mesh
Posted by Anonymous on Wednesday, September 21, 2005 12:21 AM
I'm building Dragons's excellent 1/72 T-34, and I have problem with the mesh covering the engine. No matter how low pressure I use, how delicately I try to mist it, the paint always clogs the mesh up. What should I do? Remove the paint and drybrush-it?
Posted by ABARNE on Wednesday, September 21, 2005 2:37 PM
How about trying higher pressure, thinner paint, and quickly shooting it? If you're lighty misting it, I suspect that at a microscopic level, the paint drops are significantly drying by the time they get to the mesh and thus sort of build up. I'm thinking if you can lay down a light, wet coat of fairly thinned paint on the PE mesh, the solvent will evaporate away, leaving a nice thin layer of paint on the PE without clogging the mesh.
Posted by Anonymous on Wednesday, September 21, 2005 2:48 PM
    August 2004
Posted by Tankmaster7 on Wednesday, September 21, 2005 9:16 PM
also, you can spray it, then hit it with just air from your AB which should remove the clogging.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
