I have a Badger 155. I experimented for a while and felt comfortable using the brush....so I switched from the blue I used to practice with on cardboard to a practice model with buff ( both from Tamiya). I thinned about 30% paint, 70% windex.
It seems the paint hits the model, then runs. I understand if you get spider splatter you are too close, so thats not the problem. I experimented pulling back, being close, spraying a little and trying to build up color to spraying alot and I am getting the same results...the paint hits the model and doesn't adhere...it beads on the model and runs, or gets spread by the air from the rest of the paint hitting the model.
What am I doing wrong? Thanks for any advice.
Keith
