Airbrushing Tamiya Spray Paints
Posted by Anonymous on Monday, October 3, 2005 11:15 PM
I've been airbrushing models on and off for about 20 years now and I've been airbrushing decanted Tamiya Sprays for about 2 years. Now all of a sudden I've gone stupid or something.
I'm having major difficulty in getting the Tamiya TS paint to give a proper finish. The latest episode being tonight where the white primer is being a real pain. I can lay down an initial mist coat no problem but as I build up the layers the primer takes on a grainy finish with actual dried paint dust accumulating in little 'balls' in certain areas of the model.
I constantly have to smooth the finish with 1000 grit sandpaper.
I can't even spray a gloss colour right now without this same thing happening in one form or another. The worst areas are when I'm spraying inside a confined space like the inside of an F1 monocoque. The paint is so rough the carbon fibre decals don't stick properly.
I never had this problem before and can't figure out what the hell the problem is. I've tried spraying at different air pressures - 5 psi to 15 psi but still no luck. The only thing I can think of is that the decanted paint has thickened since being decanted into jars.
I'm using an Iwata HP-C and it functions properly. It's only these blasted TS paints that are giving me problems.
What air pressures do you guys use for TS paints and what distance do spray at? Any other suggestions are appreciated.
I feel like such a newbie right now Angry [:(!]
Btw, I did go back and read the ABC's of Airbrushing article.
    January 2004
Posted by MusicCity on Tuesday, October 4, 2005 5:40 AM
Typically a rough surface is the result of the paint partially drying in the air between the airbrush and the surface, or of the paint not having time to flow and level out once it hits the surface. Since you have adjusted the pressure, and are in the range I typically use, you might try adjusting the distance to the surface and try to get closer.
Also allow the paint to dry to the touch in an area where there aren't any strong air currents, such as from a fan, that would cause it to dry overly fast.
Since the paint is decanted from a spray can I'm assuming that it is already very thin, but you might try adding a little more thinner anyway just to give it longer to dry. Some of Tamiyas paints are laquers but I'm not sure about those, I've never used them. Laquer tends to flash dry very quickly.
Posted by mass tactical on Tuesday, October 4, 2005 11:34 AM
Your airbrush is fine. Air pressure of 10-15 psi is a good range. You mentioned that your decanted paint had been stored in jars and I believe this may be your problem. When I decant paint I use it right away to aviod it thickening. I don't store it.
See if this solves your problem.
Posted by Anonymous on Tuesday, October 4, 2005 2:30 PM
I have seen mention in several places of decanting paint from a spray can to then use in an airbrush. Other than a case where you already have the spray can, is there any advantage to doing this over buying a bottle of regular paint and using it? My experience is that spray paints are noticably more expensive than bottles (and come in a smaller range of colors), but I figure there must be some reason why people are doing this.
