More Painting Fun
More Painting Fun
Posted by Anonymous on Tuesday, October 4, 2005 3:09 AM
well the airbrush i bought online for 57 i found for 30 dollars in supercheap auto (Australia), it's a double action airbrush, badger 150 clone, same parts fit basically
so i also noticed they had a badger 400 clone, called a Touchup Spraygun, with a 1.5mm needle, 200mL container, runs at 45-55 psi, and sprays the paint unthinnedBig Smile [:D]
however im having problems, even with my airbrush, where the clear coat im using (painting with an additive for colour),is making stringy white stuff that gets everywhereSad [:(], even on lower pressures it seems to do it, any ideas?
and for the badger 400, what distance from the work should i be using, 1foot?
not a bad lil buy though Big Smile [:D]
    January 2004
Posted by MusicCity on Tuesday, October 4, 2005 5:32 AM
QUOTE: however im having problems, even with my airbrush, where the clear coat im using (painting with an additive for colour),is making stringy white stuff that gets everywhereSad [:(], even on lower pressures it seems to do it, any ideas?
Sounds like you are using the wrong kind of thinner for the paint and it's causing a reaction of some sort.
Posted by Anonymous on Tuesday, October 4, 2005 7:36 AM
its the thinner from the same brand for teh same type of paint, Alac Acrylic lacquer thinner for clear coat acryl lacquer paint, so i know it aint that
ive had some clear coat and thinner mixed for 2 weeks now in a jar and it's still the same as when i mixed it, nice and thin
Posted by Anonymous on Friday, October 7, 2005 3:54 AM
it could be im in a hot humid area, should i heat my paints up a bit?
the surface i was messing around with has whitish fuzzy paint all over it, so i might just strip it bare and start playing again
im prolly using way too high a pressure, but im not sure what else will be affecting it, the paint is basically like water, but with the b400 clone i didnt thin at all, and then i tried a lil bit of thinner.
