QUOTE: Originally posted by Ghetto2k4
i can spray outdoors but it becoming winter here so..it is starting to get cold outside & my windows dont open and i work on my models in my bedroom and that where my pets are at too
Well it comes down to personal preference, as long as you excersise basic safety. Several good modeling acrylics I would recommend is, Tamiya, Polly Scale, and Testors Model Master Acryl, amoung others. These are very easy to use acrylics and are advertised non-toxic, using thinners such as water, or alcohol for airbrushing. They are inherently safe(er) than enamels and should be fine around you and you pets. Just don't let them injest it, and your related paint supplies, yourself included.
Research different brands on the web and in your area to check for availability and try a few brands. If you can't access the window or there is inclimate weather, I would at least wear a painting respirator. These are ususally available at your local department stores, Meijer, Home Depot, etc.. These cost approx. $30.00, depending on your area. Hope this helps!
Greg Williams
Owner/ Manager
Modern Hobbies LLC
Indianapolis, IN.
IPMS #44084
