Badger 155 and 360 Airbrushes
Posted by Anonymous on Tuesday, July 15, 2003 7:40 AM
Hey Guys,
Any thoughts on these two airbrushes? I know they're basically the same with the exception being that the 360 has a swivel head to change from gravity feed to siphon feed.
I'm seroiusly considering buying one of the two. What about the one tip one needle? Is it as good as they claim?
Still using my Aztec right now. First airbrush I ever had. I've had a few of the problems that everybody else has talked about but all in all, it's been a good one to start with. I'm not even going to bother to ask how the two Badgers compare to the Aztec. I think I already know the obvious answer to that one.
Posted by Anonymous on Tuesday, July 15, 2003 10:01 AM
I have the Anthem and it is excellent for medium to large work. I still own the 100 with a fine tip for small work. Just make sure you take the needle out and flush the inside with thinner and wipe it down after use. Just flushing doesn't seem to completely clean it.
