Using Tamiya TS spray paints - oversprayed
Posted by Anonymous on Friday, October 7, 2005 9:30 PM
Hello
I have been spraying a model with Tamiya spray paints and on one pieve I have sprayed a bit too much and the paint is too thick. Is there a way I can remove the paint now its dry without damaging the plastic ?
Dave
Posted by Anonymous on Saturday, October 8, 2005 9:27 AM
Easy Off is an oven cleaner that can be used to remove paint. Stripping paint and stipping chrome are pretty much the same thing. Here are my comments from a paint stripping topic.
True engine degreasers contain Petroluem Distillates(Paint Thinner) which will melt right through plastic. Cleaner/Degreasers like Simple Green and Castrol Super Clean won't melt plastic no matter how long it sits. Castrol Super Clean use to be available in an aerosol can, but was recalled a couple of years ago and never reissued. I haven't been able to find any since. I believe that Castrol Super Wheel Cleaner is just a diluted from of CSC, but I'm not positive.
Brake cleaner is mildly effective, but highly toxic. Same with Easy Off.
My recommendation for stripping paint is Wesleys White Wall Cleaner can be found at all NAPA Auto Stores. My uncle told me this will strip paint very well without hurting the plastic and isn't as toxic as other options.
My other recommendations for stripping paint are items like Pollyscale ELO and Hangar's Strip-A-Kit. These are similar to paint thinner and are effective in stripping paint. They will not harm plastic.
Windex can also be used to strip paint, but ammonia fumes are more than I can handle. It doesn't work that well either.
No matter what you use, make sure to use solvent resistant gloves, only do it outside or in a barn, and don't inhale the fumes. I recommend a respirator for the more toxic and votalie ones. You can use a 3M ScothBrite plastic pad to scrub stubborn paint off. They are green and come in a 2-pack. They will not damage plastic no matter how hard you scrub.
