Regulator for a small Paasche 1/10th HP compressor?
Posted by Anonymous on Monday, October 10, 2005 1:58 PM
I just got a Paasche D500 compressor and an Iwata Revolution TR2 (I love the trigger, btw) and I'm working through all the stuff I need to learn. I've read about different opinions about which psi to use for which application, and I guess the best way to figure out which is best (for me) is to try it out at different pressures. Problem is my compressor came only with this simple air regulator (bleeder valve) thing - just a fitting with a little screw that you adjust. So obviously I can't even tell what pressure I'm running at, the instructions just say "never run it without the valve", always set it to bleed, and to start it with the stem opened a 1/2 turn....but it doesn't say what psi that is.
So anyway, is there a rule of thumb I could use for this compressor (ie: how much of a turn is approx. X psi?) or is there a light duty regulator with a guage that I can get for this?
Any other helpful tips would be...well, helpful.
Thanks!
Rick
    May 2005
Posted by Bgrigg on Monday, October 10, 2005 2:09 PM
You can get an inexpensive regulator at Wally World or an auto supply store. I bought one at the local auto store for $10. Not the greatest, it only goes to 5psi, but who airbrushes below that? You should also get a moisture trap.
So long folks!
    July 2004
Posted by tho9900 on Monday, October 10, 2005 7:36 PM
Rick - for more money you can get the hobby style regulator with 1psi increments and a built in water trap for about $50 from Hobby Lobby or www.dixieart.com...
But as was mentioned the commercial style one will work for ya, it's not really the number that matters but where the needle is when it feels like it is spraying just right... you can eyeball that pretty good with one of the Lowes or Wal Mart type ones...
    January 2005
Posted by uproar on Monday, October 10, 2005 8:07 PM
Here is the regulator that is made for the D500--works quite nicely, and has a moisture trap:
http://www.paascheairbrush.com/cgi-bin/store/detail.cgi?r=1085
Also make sure you buy the 1/4 x 3 1/2 pipe nipple so you can use the regulator with the D500 (it's basically just a short length of 1/4" steel pipe--costs just a few bucks). The regulator and pipe nipple can be bought cheaper at www.airbrush-depot.com--the regulator is $30.40 at that site).
Posted by Anonymous on Monday, October 10, 2005 10:28 PM
Sweet, thanks for the info, guys. I'll read up on the links you provided and decide which to get. Also, the TR2 comes with that nifty pistol grip moisture trap so the one on the regulator might be over kill. I guess I could just take it off, but it makes it sorta comfy to hold the brush with it, you know?
    January 2005
Posted by uproar on Monday, October 10, 2005 11:17 PM
Actually, Dixieart has the Paasche regulator I mentioned for about $27.
