Need advice on airtanks and such...
    January 2005
Posted by uproar on Monday, October 10, 2005 8:17 PM
Greetings!
I have a Paasche VL airbrush and a D500 compressor with a regulator. I just bought a 10 gallon air tank from Sears (much to my chagrin--I would much rather have bought a much smaller tank meant for small compressors, but couldn't find one), and upon getting it home, discovered that it had a Schrader intake valve (the type of valve on car tire valve stems), and an auto tire type filler hose as on output, both securely attached and quite unremovable. Can I use this thing with my compressor? What do I need, specifically, to adapt it for my small airbrush hose and fittings? Or should I just take the darn thing back to Sears, and keep searching for a small tank meant for this sort of thing?
Thanks!
    January 2004
Posted by MusicCity on Tuesday, October 11, 2005 6:26 PM
To the best of my knowledge, which admittedly is pretty slim on the subject, I don't think you are going to find an add-on tanks specifically for a compressor. I think you are going to have to adapt a tank regardless of what you do. Before you take it back try to determine what adapters you will need and see if there is an easy way to accomplish it.
