Prime or not to Prime?
Posted by Anonymous on Tuesday, October 11, 2005 12:38 AM
Hey guys i was wondering when is it proper to Prime sufaces? will i use it for large parts and not the small ones?Do i have me when there are seams that i have fixed with putty?I'd just like to be enlightened. I have onto prily used 1 kind of primer and that is the Tamiya Fine Primer(white). How do the others compare?Smile [:)] thanks
    January 2004
Posted by MusicCity on Tuesday, October 11, 2005 5:41 AM
I prime the surfaces when:
1) I have done a bunch of filling and need to see if the seams are properly filled and smoothed. The primer eliminates the contrast between the filler and the plastic so it is easy to tell if the filling was done properly.
2) I'm spraying acrylic and intend to mask the area. Enamel or laquer primer adheres to the surface better than acrylics, and acrylics adhere better to them than bare styrene.
Other than that I don't usually prime parts. I do use the Tamiya Fine Surface Primer and have been quite happy with it except on metal parts. There are some others that are supposed to be good to though, such as Floquil, but I haven't tried them.
    December 2003
Posted by thevinman on Tuesday, October 11, 2005 10:39 AM
I always prime with enamel because I always paint with acrylics and usually, always need to putty or mask. It also helps you see imperfections in assembly.
    January 2004
Posted by knight667 on Tuesday, October 11, 2005 6:12 PM
I pretty much prime everything. I've found that it gives a really good finish overall, so I prime all but the smallest parts (and even those sometimes).
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
Posted by Anonymous on Tuesday, October 11, 2005 7:52 PM
I only prime spots where I am going to apply putty. I prime before and after puttying. I also prime for Alclad and MM Metalizers, and car bodies to get a super smooth finish.
Posted by Anonymous on Wednesday, October 12, 2005 1:23 AM
Thanks y'all! BTW scott...
QUOTE: I do use the Tamiya Fine Surface Primer and have been quite happy with it except on metal parts.
why unhappy with it on metal parts?
    May 2005
Posted by Ron Smith on Wednesday, October 12, 2005 2:17 AM
Since most of my building is done in resin I always prime. I prefer Alclad or Mr. Surfacer shot from an airbrush. No problems with either over resin, styrene, brass, aluminum, white metal, bass or balsa sealed with CA.
    January 2004
Posted by MusicCity on Wednesday, October 12, 2005 5:29 AM
QUOTE: why unhappy with it on metal parts?
Because it doesn't always want to adhere. I painted the nose gear for my A-10, for example, and after a couple of days to let it cure I could wipe it right off. Same for the nose gear on my F-15. On the other hand sometimes it works just fine.
Posted by Anonymous on Thursday, October 13, 2005 4:58 AM
if i use it on some copper wire do you think it would work? whats the best primer i could us e for metal surfaces? can metal primers basically be used for plastics too? thanks
    January 2004
Posted by MusicCity on Thursday, October 13, 2005 5:40 AM
QUOTE: if i use it on some copper wire do you think it would work?
It should. The can states that it is for metal and plastic so I'd recommend just trying it and see if it works.
That's why I was (and still am) confused about it not working on the landing gear I painted with it. It should have adhered fine, but it didn't. The first time I sprayed the parts I let them dry about 12 hours and could wipe the paint off with my hand. I thought perhaps I had gotten it too thick or noat allowed it to cure long enough although I frequently keep going abter about an hour for it to cure. I sprayed it again and used thin coats with plenty of drying time and it did the same thing. I finally gave up and used some Krylon primer and it worked OK, so I don't know what the problem was.
QUOTE: whats the best primer i could us e for metal surfaces? can metal primers basically be used for plastics too? thanks
Automotive primers, in my opinion. They are designed specifically to adhere to metal whereas model primers are designed specifically for plastic parts.
In most cases primers for metal can be used on plastic, but when in doubt try it on some scrap. Many primers are laquer-based and are very "Hot". They can etch the surface of styrene, but seldom do a lot of damage because the thinner evaporates very quickly. Any time I try something I've never used before, I try it on some scrap to see what it is going to do. This is especially true for automotive primers, and the only way to be certain you are using something safe.
Posted by Anonymous on Thursday, October 13, 2005 9:54 PM
Thanks scott..Smile [:)] the tamiya primers are a bit expensive too! thought i'd try an alternative.
