Oven Baking.. i had a thread for that one..
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=49531
tWhat type of acrylic paint do you use? acrylic paints already dry fast.. try thining it with isopropyl alcohol. if you are concerned about the paint not adhering to the surface when masking, try to prime your model first before applying the acrylic basecoat. primer makes acrylics adhere well to the surface to be painted.
remember to let the paint fully cure first before attempting to mask. 24 hrs minimum. hope this helps. Happy modeling!
