Tank vs compressor...preferences?
    January 2004
Posted by knight667 on Tuesday, October 11, 2005 6:25 PM
I have this compressor:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=47407
But I'm thinking about going the tank route. Mostly for noise, as I live in an apartment and our garage, while detached, isn't that well insulated. I'm considering this tank:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40057
Here are my questions:
1. How long will a 10gal. tank run for, flat out?
2. How long will it run, shooting paint at about 25psi?
3. Where's the best place to refill it? The HF page says a gas station would work...
4. Would it be better to get a huge bottle from a welding supply place?
I don't paint that often, but when I do I usually do marathon sessions...and I work in 1/48 and 1/35, so there's a lot of real estate to cover. One of my major problems right now is that it takes forever to fill...I still haven't completely filled my current tank.
Any help is really appreciated!
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
    January 2004
Posted by MusicCity on Tuesday, October 11, 2005 6:34 PM
If you pressurize the tank to about 90 psi (which is common at most gas stations) and then let it drop to about 20 psi you should be able to get around 30 minutes of actual spraying time. That's calculated at 0.25 scfm of flow for the airbrush which, I think, is about average.
    January 2004
Posted by knight667 on Thursday, October 13, 2005 4:26 PM
Any other thoughts/suggestions?
    August 2005
Posted by eizzle on Thursday, October 13, 2005 4:56 PM
one more thought, a welders type tank is really expensive. Most of the time you can't buy them, you have to lease them from the gas supplier. Keep that in mind if you go looking.
Colin
 Homer Simpson for president!!!
    April 2005
Posted by T_Terrific on Thursday, October 13, 2005 5:23 PM
I have a dumb question.
Why not just buy the Harbor Freight Air Brush Compressor?
I have one and it is nice, small, and relatively quiet, and easy to switch on/off.
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
    January 2004
Posted by knight667 on Thursday, October 13, 2005 5:29 PM
You mean this one?
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=92403
    July 2004
Posted by tho9900 on Thursday, October 13, 2005 7:29 PM
hmmm... have you thought about getting a long airhose, leave your compressor in the garage with the hose run to your modeling room? It would be a lot less noise! with the 2 gal tank it would only be coming on every so often as well so it wouldn't even be a constant hum outside... just a buzz every few minutes...
Someone here has their system like that.. I forget who at the moment though... I might go for it as well as soon as I clear room out in the garage. My brother in law is a contractor and told me he would run the hose through the wall for me, come out of the wall with a quick disconnect mounted with a wall plate (kinda like where ya plug the cable TV in) then I can just connect the AB manifold from there...
    January 2004
Posted by MusicCity on Thursday, October 13, 2005 7:50 PM
QUOTE: Someone here has their system like that.. I forget who at the moment though...
Mine is like that. The compressor is 50' from my bench and it makes a HUGE difference in sound volume (sound volume decreases based on the square of the distance from the source). I also have a second moisture trap and regulator at the bench and a "T" fitting so I have unregulated high-pressure air for blowing things off. Looks like this:
    July 2004
Posted by tho9900 on Thursday, October 13, 2005 9:00 PM
ahhh thought it was you but wasnt sure... it's been a long work week...
Sad [:(]
    January 2004
Posted by knight667 on Friday, October 14, 2005 10:46 AM
Unfortunately, my workshop is in the garage. :( So that kinda limits me.
Flat out, how long should a 2-gallon tank take to fill?
    July 2004
Posted by tho9900 on Friday, October 14, 2005 7:42 PM
from dead empty I would guess mine takes about 2 to 4 minutes.. after that no more than 20 to 30 seconds for the quick fill ups... and that doesn't happen but every 10 min or so depending on how heavy I am spraying at the time...
if it is late I just turn off the juice and use it till it is too low to spray... that usually gives me about enough time to spray the fuselage main color on a 1/48 size plane with a little to spare...
Posted by Anonymous on Friday, October 14, 2005 8:31 PM
Hi, I am new to the forums and to airbrushing. I was faced with the same dilemma as you and decided to go with a compressor similar to your posting for Harbor Freight. My 2 gal compressor made alot of noise and was bulky A friend of mine who does alot of airbrushing on model trains sold me a Thomas Sprayit compressor that he used. He purchased a similar compressor that had an automatic shutoff when the airbrush wasn't in use. These oil less diaphram compressors pump out more than enough psi to operate an airbrush and you want to talk about being quiet. Mine sounds like an aquarium compressor. Perfect for what I need, light weight and easy to store. The one you posted seems like a good deal since it include the regulator and water filter. I need to purchase this for mine and the best price I found was $34 including shipping. I am not an expert on this type of airbrush system, but it works for me. I would like to say that I do enjoy reading the postings and have learned alot. I hope this helps. Mickey
    July 2004
Posted by tho9900 on Friday, October 14, 2005 8:34 PM
Mickey... welcome to the forum! Glad you made it here and hope you enjoy!!!
Posted by Anonymous on Friday, October 14, 2005 8:51 PM
tho9900, thanks and I have enjoyed it already.
Mickey
    October 2005
Posted by looper on Sunday, October 16, 2005 10:17 AM
after shipping that 10 gallon tank will be around $40. for that you can get two 7 gallon air tanks from walmart. thats the route i'm taking.
Andy
    April 2005
Posted by T_Terrific on Tuesday, October 18, 2005 4:17 PM
You mean this one?
Yep, that's it Smile [:)]
Tom TCowboy
    January 2004
Posted by knight667 on Wednesday, October 19, 2005 4:01 PM
How easy do you think it would be to attach a pressure regulator to it, so I can vary the pressure coming out?
    January 2004
Posted by knight667 on Wednesday, October 19, 2005 5:00 PM
Well, I contacted Harbor Freight about my tank never filling, and the technician I talked to said it sounded like the Pressure Control System. They're sending me an RMA label so I can send it back, and then I'll be getting a new one once they receive this one. Hopefully I'll be all back up to speed in a couple weeks...not sure what I'll do in the mean time...just a lot of building, priming and seam-work I guess. :(
Posted by Anonymous on Wednesday, October 19, 2005 6:42 PM
Hi folks,
I was wondering if anyone had personal experience with the compressors listed in Harbor Freight. Specifically, whether anyone knew if the previously mentioned, $50 Central Pneumatic kit http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=92403 is quieter than a Paasche D500. For the price, it comes with a (semi-adjustable) pressure guage & filter, teflon tape, et cetera, whereas buying a new pressure regulator/filter would be very nearly half the cost.
I recently purchased a used D500 off of Ebay, and now I'm slightly regretting being hesitant on buying the Badger rebuild compressor offered in their garage sale.. but seeing as I'd probably need a moisture filter anyway, perhaps getting the kit from harbor freight may be the way to go. For the record, I'm choosing to start with a badger 150, as dual-action was a universally suggested choice.
From what I've researched, Central Pneumatic is a Chinese outfit with hit-or-miss products, (much like Campbell-Hausfeld, an American company), with no website to investigate. Also, as far as I can tell, Airbrushcity.com rebadges many of the compressors from Harbor Freight and slaps their logos on, and charges a premium to their customers.. observe the similarities in heatsinks on the top of these compressors:
http://www.airbrushcity.com/1601.htm
In any case, in testing the Paasche D500 I feel like I really should be operating power tools..
While I'm on the topic of (hopefully) quiet compressors, I also was wondering if Campbell Hausfeld's 2 gallon FP2040 "quiet compressor" was indeed as advertised.
http://aircompressorsdirect.com/catalog/product_info.php?cPath=3_180_26&products_id=119
Several posts in this forum show that there is indeed a huge difference between the FP2040 and the FP2048, but how comparable are these tank compressors to the small airbrush diaphragm compressors? I know the tanks will enable a steady supply of air, but the initial tank pumping may also be a bit loud..
Thanks for any advice.
    September 2005
Posted by nathaniel on Wednesday, October 19, 2005 8:08 PM
jagerk -- you pretty much figured out the china thing. Another interesting thing is that a lot of companies are actually the same stuff from china. I wouldn't be surprised to discover C&H has the same electric motor as the central pneumatic one. Doesn't this look suspiciously like C&H's product?
I also don't find any of their stuff all that unreliable. It's pretty decent stuff. Whether or not that $50 compressor will work for you is a matter of your airbrush. I have a Paasche VLS and find it uses more air than most other airbrushes. .7 CFM at 30 PSI is simply not enough for me. I need around 1 CFM at the pressure to get a good spray with some of the things I'm putting through my airbrush (I could probably thin them more and reduce pressure, but I'm currently getting good results).
I use the C&H 2050 and find it is about as loud as a vacuum cleaner, but more distinct. I also find that it struggles with the last (getting from 90 to it's cut off at 100). It does it, but the engine starts making a cyclical pulsating sound like it's really working hard. Usually what I do is start it up, stop it at about 50, start it again after a few minutes, stop it at 75 and then wait a bit longer and then go for the last 25. That way, it seems to never make that sound and doesn't sound like it's working too hard. I suppose that's not the best review of the thing to say that I fill it up in stages because I'm afraid it can't take doing the job it was designed to do. I got it for considerably less than that link you provided, so I consider it a good buy.
I'm at the point where I honestly don't know what I'd recommend for anyone else nor what I'd get if I had to get a new one.
Posted by Anonymous on Wednesday, October 19, 2005 8:36 PM
Wow, thanks for the quick reply. In any case, I stated I've got a Badger 150 dual action ab to start off with, and I'm not yet familiar with what kind of CFM at what pressures is a good setup. The paasche d500 I mentioned has relatively weak stats of 0.5 CFM at 20 PSI, whereas a badger 180-11 is spec'd at 0.90 cfm per 20 PSI.
In any case, thanks for your input, it's exactly the type of information I'm looking for. Vacuum cleaner decibel levels make me sad :(. At least you've got a tank to get some quiet time for yourself.
Perhaps an inner tube will do nicely for my purposes.... or that damned out of stock garage sale Badger compressor..
    September 2005
Posted by nathaniel on Thursday, October 20, 2005 5:10 PM
The badger 150 (sorry for missing that before) does not require a lot of air. Any of the compressors talked about so far would be sufficient. It is still a syphon feed though, which means that if you can get a bit more SCFM at a given pressure that wouldn't hurt.
As for the vacuum cleaner level, I really don't find it that bad. I have it about 10 feet from where I spray and can tolerate it just fine. I have a long hose, so if I was concerned about the noise I'd just pop it a ways away. I think that it's about perfect for the VLS and would be more than enough power for the Badger 150.
After giving it a bit of thought, I think I'd recommend a compressor based on what the person was willing to risk. I started off with a cheap used Harbour Freight Oiled monster comrpessor. It was so loud that my housemate thought there was construction going on down the street. That thing died on me a short while after I used it. I took a risk and blew $50 on a used compressor because I wanted to make sure I had enough pressure for the VLS. Then I went and got the H&C and I'm basically happy with it (other than I like to give it a bit of a rest along the way to reaching maximum pressure). I'm definitely the kind of person who would go wih the Harbour Freight airbrush comrpessor for $50 if I had a different airbrush.
Whatever compressor you get, if you find it pulses then the simplist solution is to get a longer hose from the hardware store. It'll act like a miniature tank of air and should cut out the pulsing.
Posted by Anonymous on Thursday, October 20, 2005 9:11 PM
Knight, I suggest you check out a CO2 tank. These are the same tanks they use for carbonated drinks. They are cheap to fill and when they run out you just take them back and swap them for a new one. Soft drink vendors can tell you where to get it filled. Since soft drinks are widespread, so are the filling locations.
I get maybe 15-35 models from each tank, depending on how much I have to spray. No noise, no moisture trap, no dirt - just clean, dry gas.
It is nice to just turn oun a valve, hook up the hose, and start spraying in blissful silence.
PS I have a large shop type air compressor that I have also used, and I still prefer the CO2 tank.
    January 2004
Posted by knight667 on Friday, November 4, 2005 3:56 PM
Just a little update for those who are curious. I've requested a refund for the compressor I sent back to Harbor Freight and am picking up a CO2 tank this afternoon/evening. I'll be trying it out tonight after I get home or tomorrow at the latest. Looking forward to having silent instant air at my disposal.
Will post my results here as soon as I've tested it out!
    July 2004
Posted by tho9900 on Friday, November 4, 2005 5:14 PM
cool - it would be interesting to see how you like it and a rough price on what it cost to get the thing...
    January 2004
Posted by knight667 on Friday, November 11, 2005 1:47 PM
Here's an update for you guys/gals on my CO2 tank.  It works beautifully!  I shot a base coat for my F-4F last night and it was amazing!  I could hear my radio (classical music), and concentrate on what I was doing without being deafened by a stupid compressor.  Paint went on smoothly and perfectly, no fluctuations in pressure, no water spitting, no problems.  Pressure remained right at 20PSI the entire time I was shooting.
Total cost was $184 for the CO2 tank, complete fill and nitrogen regulator (they used a nitrogen one because the PSI adjustments were smaller than a standard CO2 regulator).  The welding shop I went to changed out the fittings for me for free.  Worth every penny of it!!
I'll post pictures on Monday of my F-4F so you can see the paint finish.  Looking forward to shooting Future with this thing as well!
Posted by Anonymous on Friday, November 11, 2005 3:42 PM
do you know what it costs to refill?
    January 2004
Posted by knight667 on Friday, November 11, 2005 3:48 PM
$13 from the place I bought the rig from...according to ChemMan here on the boards, he only fills his every year or two, so I'm estimating the same.
Posted by jhande on Friday, November 11, 2005 4:12 PM
I remember long ago a friend of mine used an automotive air tank, the kind for filling up flat tires. He said that worked pretty good as he would stop at the gas station on his way home from work and fill it up with air.
Wonder if anyone still has good experiences with doing that?
-- Jim --
"Put the pedal down & shake the ground!"
    January 2004
Posted by knight667 on Friday, November 11, 2005 4:21 PM
I've heard mixed reviews on those...pressure drops fast, from what I understand.
