Spray Booth Blueprints
    July 2003
Posted by MonsterZero on Tuesday, July 15, 2003 10:53 PM
Some people swear a fully-functional spray booth can be assembled with fairly rudimentary tools and supplies. If anybody has a link to online blueprints of something like that I'd love to see.
I'm thinking about something I could show to the guys at Home Depot or Ace Hardware, get the components and assemble myself. If it requires sophisticated carpentry skills & tools it's not for me.
Posted by midnightprowler on Wednesday, July 16, 2003 4:38 AM
I have a article FSM did a couple of years ago on building a booth. Send me your email or snail mail and I'll send it to you.
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by Anonymous on Wednesday, July 16, 2003 10:06 AM
As a counter to building a spray-booth, or paying upwards of $100 for one, I pursued this angle from Harbor Freight Tools(big picture copied from the site, so bear with me):
BENCHTOP ABRASIVE BLAST CABINET WITH LIGHT
Strip paint, polish and clean material. Portable enough to use on a workbench. 15VDC light provides viewing for intricate work. Includes rubber gloves, blasting gun with trigger, 4 assorted ceramic nozzles, dust collector port, hopper and screen. Powder coated.
115 Volts, 60 Hz
Required air pressure: 80 PSI, 5 CFM
Required hose ID: 3/8''
Viewing window: 21'' x 17-5/16''
Working area: 18'' x 22'' x 11-1/2''
4 nozzles: 4-1/2mm, 5mm, 6mm and 7mm
1/4'' NPT air inlet
ITEM 38440-2VGA $99.99
Granted, the $100 price tag may seem daunting, but they put it on sale for $70 regularly (which I paid).
Just remove the silly gloves, put a small fan or vacuum cleaner on the end of the filter, and have a day! VERY easy to use, cheaper, and a heckuva lot more solid. Plus, since it's a blast chamber, getting paint on the grille isn't a major issue.
I looked around at different ideas/blueprints for spray booths, and this was the best all around.
No, I don't work for Harbor Freight, I just get their ads.
    July 2003
Posted by MonsterZero on Wednesday, July 16, 2003 7:32 PM
Lee
prowler, thanks for the offer. I just activated the "show my email" option. Just click and send.
Posted by ga.retread on Tuesday, August 5, 2003 10:39 PM
MidnightProwler - I just saw your reply re: spray booth plans- Would it be too much trouble for you to e-mail them to me also? Much appreciated.
"Shoot low boys, they're riding Shetland Ponies!" - Lewis Grizzard, revered Southern humorist
Posted by Anonymous on Wednesday, August 6, 2003 1:07 PM
Hey could someone send some buleprints to me or a good cheap place to buy one.
Derrekjm@aol.com
Posted by Anonymous on Wednesday, August 6, 2003 7:14 PM
Model Railroader had a much better booth several years ago than the FSM version. I will have to look through my folders of old articles I saved to find the issue number. Perhaps someone connected to Kalmbach here could post that.
With a little skill with pop-rivets and careful measurement and cutting (access to a small shear and press brake would help alot) could be built. You can buy the sheetmetal at home depot etc. I plan on building mine out of titanium when I finally get around to it (0.020") - cause I have access to lots of it.
The filtering system in the Aztec/Testors version (I think) with the roll of filter media looks nice, but down the road it would probably be much easier to find filters used for appliances, furnace filters liek the filtrete type probably too big for most.
Posted by Anonymous on Friday, August 8, 2003 8:36 PM
JQUINN,
are you into model trains? Email me off line if you have gotten a hold of that issue...
Posted by Anonymous on Saturday, August 9, 2003 7:06 PM
plans instructions were in the January 1988 issue of Model Railroader (paintshop by Andy Sparandeo)
Posted by Anonymous on Saturday, August 9, 2003 9:31 PM
I'd be interested in seeing that article too! Hopefully someone is able to share it??
Murray
Posted by cnstrwkr on Tuesday, August 12, 2003 8:36 PM
Ok Monster, I was rummaging around on the net and found these links. Hope it helps.
http://www.culttvman.com/kirk_schermerhorn_s_paint_boot.html
http://www.interlog.com/~ask/scale/tips/booth.htm
Tommy difficult things take time...the impossible, a little longer!
Posted by Anonymous on Tuesday, August 12, 2003 10:31 PM
The second link is pretty cool
    December 2009
Posted by wildwilliam on Wednesday, August 13, 2003 12:52 PM
i am currently working on a "Franken-Booth" for my work area.
there has been a work stoppage as the tools/workshop i am mooching time and tools from has been busy. (my friend has a life other than working on my hare-brained schemes, what can i say!)
but the basic plan is:
24" x 36" 1/2" plywood back
two 24" x 24" 1/4" clear acrylic sides
one 24" x 36" 1/4" clear acrylic top.
sides and top hinge to the plywood back, so booth can be folded into
a 24" x 36" box about an inch or so deep and put under my bed or couch.
box has no front or bottom as it is designed to sit on top of my 41" x 30" work table. i am going to replace the current table top w/ one modified for a downdraft
fan exhaust.
for other folks, you might be able to mount a fan on the plywood back or the top,
but it would not fold up as flat.
fyi - i got the acrylic sheet from a local plastic supply place. they sell it in 4 x 8 foot sheets. they charge $15 to cut (my cuts were 4 side squares, two top rectangles, two 10 x 18 inch "windows" i will put in the wooden back for more light to get in) total for sheet, cut charge & tax was abt $120. but there are enough pieces there to make 2. i am giving the second one to my friend.
i realize the size is overkill for most folks.
but the same design would work smaller.
i just wanted to be sure there was room for my Braille scale planes. :-)
and a 1/72 B-52 that might be a bit big for those 12 x 20 boxes.
once we get back to work co-ordinating our schedules, i will post back on progress and problems.
one thing i DO know : it is hard to get plywood that measures 24" if you buy a "quarter sheet". so check that first before you have the cut the acrylic !!
if you are going to make a box more in the 20 x 30 range, it won't be an issue.
ed.
Posted by J-Hulk on Thursday, August 14, 2003 8:36 AM
Sounds like you've gotten a lot of good info from all the fine folk here, but nobody mentioned the fact that King Ghidorah rocks!
You a kaiju fan by any chance?
~Brian
    August 2003
Posted by Bradley M3 on Sunday, August 17, 2003 11:05 PM
