First Time Use of Alclad
Posted by Anonymous on Wednesday, October 12, 2005 3:29 PM
I'm looking into using Alclad 2 for the first time, and I was looking at the site, and didn't know which instructions to follow. I am going to be painting a resin surface and I didn't know if I needed to follow the polycarbonate/lexan instructions or the regular plastic instructions. It's always been my understanding that when using Alclad it's very important to follow the instructions precisely, and I didn't want to mess this up.
    July 2004
Posted by tho9900 on Wednesday, October 12, 2005 8:13 PM
I would follow a mix of the two directions... first.. use the lexan directions and THOROUGHLY wash the exterior to remove release agents and such... but then I think you would be good with either future or black krylon as a primer... which is more the pastic side of things...
Good luck to you! I think you will love the stuff once you use it... if you have a spare model (as in a junk model) it might be good to try your hand at it first... not that it's any arder to put on than regular paint but knowing how it goes on helps...
    January 2004
Posted by MusicCity on Wednesday, October 12, 2005 8:58 PM
To take what Tom said a bit further, Alclad is very, very sensitive to the underlying surface. If the surface is at all rough the roughness will show through the Alclad paint. Since resin tends to be a pit porous, or at least more so than styrene, I'd pay particular attention to getting the surface as smooth as you possibly can.
