Masking Question
Masking Question
Posted by Anonymous on Monday, October 17, 2005 7:30 PM
I was wondering, do you remove a masking tape mask before or after the paint is dry?
Posted by Anonymous on Monday, October 17, 2005 7:37 PM
I remove it right after I paint the model. I've found that if I leave it on for a while there may be a chance that the still wet paint will run under the tape if it hasn't already. just my My 2 cents [2c]
    July 2005
Posted by clairnet_person on Monday, October 17, 2005 7:46 PM
Sign - Ditto [#ditto]
Current builds: Monogram P-40B Revell F-15E
    January 2004
Posted by MusicCity on Monday, October 17, 2005 8:49 PM
I usually paint in relatively thin coats so effectively everything that is masked has been left to dry several times already. After the last coat I usually go ahead and pull the tape, but even then the paint is usually dry to the touch since I normally paint with acrylics.
    December 2003
Posted by thevinman on Monday, October 17, 2005 11:25 PM
Same here. Several light coats helps keep paint from "wick-ing" under the tape.
Posted by Anonymous on Tuesday, October 18, 2005 1:54 AM
Sign - Ditto [#ditto] all the wayBig Smile [:D]
